Crashes with opening Asset Editor (VRAY)
Hi, do you have any experience with crashes when opening the vray - asset editor ? When I open the Asset Editor, every time opens the warning: Upgrading V-Ray components -
This file will not work with previous versions of V-Ray for SketchUp. And then the Sketchup shut down and then window with BugSplat open. I don’t have any chance to render something or do something with that.
I have MacOS Sonoma the newest one and also Sketchup 2024, Vray 6.
I currently have the same issue.
Using Vray , Sketchup 2024 on macOS Sonoma.
Did you find a solution to this ussue?
Same here as well. This just started happening after upgrading from Vray 6 to Vray 7 (which we have been instructed to do by Trimble before January 28).
Indeed. Also appeared since the update, but I re-installed Vray 6 since then so everything is working fine again, for now.
Hopefully they fix this issue before their forced update by January 28.
You only need to update the VRay license server - AFAIK you can still run an older version. And this didn’t come from Trimble but from VRay.
I don’t believe you need to update the entire software, only the license server.
