link for ref; PINECONE MEDIUM
If you need it to exactly connect the edges of the “cage” you could use Curviloft. If you just need the rough shape of a “bulb” inside the cage you could do it with native tools pretty easy… I would probably just draw a sphere and use the scale tool to deform the hidden edges.
With Soap Skin & Bubble
Thanks Aaron for your quick reply. I want to make exact like below image.and i dont have wire mesh it is tubular geometry.
Thanks mihai.s i dont have wire mesh,is it possibe to do same with tubular geometry.
You’re welcome!
Those tubular elements are made of edges and faces. Just select a loop edges and delete the rest
Thanks once again. You really helped me.
You’re welcome!
And this is if you want (recommended) to create the path in the middle of the tube
super helpful. appreciate your time for my issue mihai.s.
