How do I copy a set of elements from one project into another in the same spot?
I read the guide from Feb '19, but the solution doesn’t work for my '23 version.
Thanks
Thanks
So [Edit]>[Paste in place] does not work in SU23?
At this moment i don’t have SU23 installed, so this sample was made with SU22, but should work the same? ![]()
If you are using 2023 windows version this will help you:
Thank you, this helped!
Thank you, my paste options were greyed out since the program will think nothing is copied from the second file. As the next comment states it worked if I copied a random object in P2 and then copied the correct element in P1 and then I could paste in P2 as you show.
