Copy from one drawing to another drawing
With the new version 23.1.319 SketchUp Pro I can no longer copy from one drawing to another drawing.
I used to be able to select an object, type ctrl-c, and then paste that selection into the new drawing. This no longer works. I’m using
Copy and paste between open files is broken in 2023.1 for Windows, it is a bug. There is a temporary solution which will restore the capability for that session which is to copy anything in the second instance. The directions are in this post.
Great! Thank you, that works for me.
I had the same Issue, this works for me too. Thanks!
