I am experiencing a very odd problem: copy/paste in place and cut/paste in place do not work! One of the simplest things one can do in Sketchup and it is not working 90% of the time. All I get is the annoying error sound.
I suspect there is a problem with this file as it has been crashing a lot.
How big is the thing you’re trying to copy or cut? I’ve had cases where it didn’t seem to be working but it’s because what I was copying or cutting was huge (loads of geometry) and it was just taking a long time to get it to the clipboard.
Have you tried copying the relevant parts of your model and pasting them into a fresh model in an attempt to sidestep whatever is causing the problem.
You can copy from Outliner if everything is in groups and components.
Is it normal on Mac to get an error sound if you try to paste something unsupported, e.g. text? On Windows you get no feedback in such cases, like when there is nothing in the clipboard. Also, in the Edit menu, is Paste enabled or grayed out? I’m thinking some other program may put unsupported data in the clipboard.
I was thinking about the same. Unsupported data. On windows, you can clear the system’s clipboard and you now have the abilty to check the settings on multiple copy functionality (history clipboard). You can also clear the clipboard.
I used an app for multiple clippings on a Mac, but I can not recall if that ever caused problems in SketchUp. Nor do not know how to clear the contents of the clipboard
There is no built-in command to clear the clipboard on Mac and the native clipboard holds only the most recent item, not a stack or history. There are add-on applications that provide a multi-level history, but I’ll assume @edson is not using any of them as he didn’t mention it.
@edson, does copy/cut - paste work in other apps? Have you tried restarting the system (that clears and restarts the clipboard process).
You can see the current contents of the clipboard via the Finder menu Edit->Show Clipboard. This will open a window that tries to display the current contents. Unfortunately, its ability to present them is pretty limited. What you see depends on the type of the contents. For many kinds of proprietary contents (including cut/copy from SketchUp) the window is blank and says “Clipboard contents: unknown” in its bottom border. So, showing the contents will clear up the situation only if the contents are something that Finder recognizes but SketchUp can’t accept. Worth a try, but not a high likelihood of giving an answer.
What happens when you paste? Nothing happens? Are the contents that you are pasting tagged with a layer name or tag name, and is that layer to tag set to be invisible in the destination model?
The last few days my computer freezes up when I try to copy even small items using either the Ctl/Move or the copy/paste. All worked fine two weeks ago. Is it Windows, or Sketchup, or what?
Is this in SketchUp 2019 as indicated by your profile? If so, that hasn’t changed in years so if this is new behavior, look at what has changed on your computer. Share the .skp file so we can see what you’re working with. What are you trying to copy?
Hi, Dave
I was very happily surprised to hear back regarding my problem. The most important thing was finding out from you that I was not one of thousands with this problem, so I knew it was local. I cleaned up my hard disc, and then realized that PC Matic does that every few days. So then I uninstalled Sketchup 2019, 20, 21, and 22, figuring that they might be interfering somehow with 2023. That solved the problem, and now I can copy small and large (like whole houses) without any problems. I did notice that my 2023 is not Pro like the others, but I’ll figure out how to fix that. I also had to reinstall some extensions, but that wasn’t too bad. We’ll never know what the problem was, but being a computer development engineer in a prior life I’m not surprised. Sometimes computers just go off into the weeds and can’t find their way back. Don’t let one drive your car.
Thanks again,
John
