Converting .dwg compents
263026 2 x 2 12 3 way cpvc .dwg (4.2 MB)
My question has surely been answered before . But I cant find the answer searching through the older post .
Can someone please point me toward the best method to convert and use copied .dwg models in Sketchup. I have tried clowing them up 100% and cleaning with the Thom Thom Clean up extension . yet they are still too heavy to use . Attached is one of several components I am attemting to use as an example .
Thank you
How are you going to use the model once you have it cleaned it?
Are you still using SketchUp 2021 as your profile shows?
Im using several ( 6 or more ) these valves, along with a couple other .dwg converted components that are likely more complex. I am using them for the purpose of illustrating a Pool Filter Equiipment installation ( see attached Pdf from Layout ).
The file size after my attempted clean ups still easily / greatly exceeds the capability of my computer nearing 600,000 KB . All this also exceeds my understanding of system limits lol. I just know its 6 x greater than the typical project that I work with . I am using SU 2024. Thank you
Equipment sett PS no heater Isometric View.pdf (291.5 KB)
Equipment sett PS no heater. blank dimensions pdf.pdf (381.7 KB)
This file is typical of something made from a model created for manufacturing documents. There’s a lot of interior detail that would never be seen in the sort of documents you are creating. If it was my project I might import the thing to use as a reference but then I would create my own much simpler model of the valve and then delete the original and purge the unused components from the model. I expect you could make a suitable model of the valve component that is less than 1 Mb.
Please update your forum profile. It says you are using 2021.
I appreciate the the sound advice. It occurred to me I could have duplicated the various components in my diagram within the time I have spent watching the beach ball rotate while my system is frozen .
Of course these challenges often present opportunity to learn. I will redraw all these items. Thank you for telling me its the most practical way Thank you for helping me along.
