Converting Autocad to Sketchup
Hello is it possible to convert Autocad files to Sketchup? I am wanting to add some lighting and furniture etc that is avaiable as DWG but not (as far as I can see) Sketchup.
I do have access to CAD so can convert in there if it is possible. Thanks.
yes.
I suppose they are DWG files ? 3d DWG ?
then file / import and off you go !
you might have to tweak some import settings, and you’ll have to re-colour the models I guess.
if they are a different format than dwg / dxf then… well that depends :slight_smile:
There are also limitations on what SketchUp can import. Some things are noted in the post-import dialog. Things that came from proprietary CAD extensions or that refer to external resources generally can’t be imported to SketchUp.
Thanks!
We have a great free course on SketchUp Campus!
https://learn.sketchup.com/courses/3-ways-boost-your-cad-3d-workflow
Also check this tutorial:
In case you want them Mtext and hatches as well…
PXX875D67E.dwg (145.7 KB)
I have tried importing this but can’t seem to import to Sketchup?
It worked for me. To what do you have the Units set in the Import options panel? I set the import units to Meters. You might need to scale it down, though.
I fixed incorrect tag usage in the attached.
Screenshot - 9_28_2024 , 2_08_54 PM
It worked well with Millimeters too. I ran ThomThom’s Cleanup3 on it too
Untitled.skp (135.4 KB)
Are you running the latest update of v.2023? If not, you might try installing that, or updating to v. 2024.
I am not too savvy so not sure what this all means, sorry! Where do I set the units please? Thanks
Open the importer and click the options button before you select the dwg to import. Choose the import units in the options dialog.
Thanks
