Context Position Texture Not Appearing
Straight Edge #1.skp (119.7 KB)
I get the Straightedge into the edit context, select a face, right click, but position texture does not appear. It used to work. What do I need to do to get the position texture option to appear in the context menu?
Your surfaces are made of multiple faces. The Position Texture thing only works if you right click on textured single face. Turn on Hidden Geometry and then right click on just one face.
I would suggest removing the materials from the component containers as well.
I was able to open the position texture option in the context menu when I had hidden geo. selected. I do not know what you mean in the quote above. I looked into materials, components, entity info, and model info. I did not see an option or how to remove materials from “component containers.”
If you look in Entity Info and select the component you’ll see it has a material applied to it. You can repaint it with the default material. For most modeling you’ll want to apply materials to faces not component containers.
mat
Thanks for the video. I got it and fixed it.
