Configuring live components units
Hello
Live components downloading in mm, not inches. I’ve check my Model Info units set to inches.
Is there a fix?
Thanks
Hi @DNoelOKane - that’s definitely a bug! Will pass it on to the team.
Thanks for letting us know!
Okay. First time I opened it was mm, second time inches, 3rd time back to mm.
Thanks,
Daniel O’Kane
I also posted this a while back with no response.
Menu, when opening, jumps up to screen corner with menu bar disappearing and you can access open/close.
I have to restart program. Happens a lot.
Layout - SketchUp Model Menu Stuck in Corner
forums.sketchup.com
](https://forums.sketchup.com/t/layout-sketchup-model-menu-stuck-in-corner/347236?u=dnoelokane)
Thanks,
Daniel O’Kane
I see this too. Fix?
Any updates on these issues? Still happening. Longtime paying customer here so would be nice to get an update as I use the program daily.
We’ve got a fix in the works for the units on an LC; it should be out soon. Thanks!
What’s an LC? Also what about the issue of the menu getting trapped in the upper right corner. Still happening
Live Component
As for the menu getting trapped, best to ping @trent from the LayOut team (which I see has responded to you a bit on your linked post)!
