Complex slicing of a helix
Hello,
I wonder if anyone knows of a way to remove the circular faces of this model while leaving slots in the uprights in some sort of automated or global way?
I can do it with section planes and Zorro2, but it takes multiple slices per upright and still leaves me with the slots filled in. I also tried Eneroth Slicer, but it crashes with so many faces.
What I’m trying to do is go from this:
To a set of uprights only, which look like this:
Thank you,
Cameron
CSL-extra-coil-10-2-1.skp (14.7 MB)
If the geometry of all your uprights were in a single solid component or group and helix is another single solid group or component, Subtract from the Solid Tools, Eneroth Solid Tools, or BoolTools 2 should be able to create the notches in a single process.
I made an example.
I would suggest skipping the use of materials in your model that you are setting up for 3D printing. They will just slow things down.
@DaveR, you are the man!
It took about 7 minutes to perform, but worked like a champ.
Thanks for the tip about the textures. Will do.
(Sorry some reason, the gif file size limitet to 5MB - istened of 10 previously - so the quality is reduced too… :frowning: )
copyfacepp_rc
Then you can use Rotate tool to make an array of the new component.
Nice, but in this case, each upright is unique due to the slots being a spiral.
This part is called the “Extra coil”:
Ups… I didn’t notice that… :blush:
Please post a picture of whatever it is you’re building while it is running after you complete it!
