Aparece que as fontes estão ocultas. Ja fui no painel de controle e não acho onde configurar. No winsdowns diz que as fontes estao intaladas. O que devo fazer?
Translated by Google:
What version of SketchUp are you really using? Your profile says 2022 Make which is impossible since there is no such version. What operating system?
Sketchup uses fonts installed on your system. 3D text only supports TTF fonts. 3D text in the Web version has built-in fonts that cannot be changed or added to.
2022 pro e windowns 10
Ele não tem altera nem o texto simples e nem o texto 3D, diz que é para entrar no painel de controle, mas ja entrei e esta normal
Please correct your profile.
Did you install SketchUp correctly? That requires right clicking on the downloaded installer and selecting Run as administrator. If you didn’t do that do it now and when the option is presented choose Repair.
