Total newb here, and I’m trying to change the axes a component will glue to a surface on. Every tutorial and forum post I can find referencing this says to right click the component and select “Change Axis.”
Problem is, this option is completely missing for me, and I can’t find any equivalent option anywhere.
The component I’m trying to work with is a simple 1x6 board so I could just create a new one and get the axis right from the first place, but then I would have to create multiple component copies if I want it to glue from a different axis, and it would only get worse for me with more complex components in the future.
Using the select tool, I can select faces of the component, and edges, and the whole component as a group by click dragging, but it still seems to register the object as its individual parts rather than a single component, which still brings up the same menu. How do I make the selection treat the object as a component?
Now that I’m looking at your image on a pc rather than my phone I can tell you what you have selected in that image is not a component, it has no bounding box neither open or closed.
