Can't push pull surface
By “somewhere”, I did of course mean “meaningful endpoint”. Must have been autocorrected when I posted…
Hey - I’m having a similar problem. I drew a component, saved it as a component, reopened it for edit but still can not turn it into a push/pull “thing” (yes, I’m new to Sketchup.).
Can you help?Headboard Base.skp (155.3 KB)
The Sketchup Fundamentals is a great resource. The tutorials are interactive with learning materials.
The ‘extrusion’s’ ‘outline’ in not ‘coplanar’.
Therefore it cannot support a single face.
Its two vertical [colinear] edges should be erased.
Then you can redraw a new vertical line.
The expected face will then form.
Then you can PushPull that new face as desired…
