Hello everybody,
I have a problem creating windows on one of my walls.
Can someone tell me whether or not I have to start over again?
Here is the file:
The Boss’s Spot.skp (365.2 KB)
Hello everybody,
Here is the file:
Delete all the excess hidden edges that split the wall in front to triangles and you can punch holes to it.
Turn off “length snapping” in Model Info>Units. I didn’t have the time to check if it has caused some of your wall faces to be non-parallel.
Use components and groups to prevent your model becoming an unmanageable mess of faces and edges.
See learn.sketchup.com and the SketchUp YouTube channel for more.
Did you by any chance import a DWG or DXF file to start this model? I used to see this in my work when I used to use that imported linework for the model itself. Now I just use the DWG import as a reference to snap to as I model with native tools and I haven’t had the problem in years.
Hey Anssi,
Thank you for sending me the link. This was a refresher to my understanding of using SketchUp.
