Im on a new laptop with different new keyboard configuration and its not very ergonomic to use the delete key.
When I try to asign ‘backspace’ for edit/delete I get
“Key cannot be used as a shortcut dialogue”
Windows 10.
Any thoughts. Cheers.
Windows 10.
https://help.sketchup.com/en/sketchup/customizing-your-keyboard-and-mouse
…So: That’s it. ![]()
Yeah I assumed that might be the case. What confused me is that the ‘delete’ key is obviously assigned to edit/delete by default but if I remove this assignment with the “-” button sketchup prevents me adding it again. (Perhaps for the same reasons mentioned above) I have to cancel the shortcut alterations so that it doesn’t save the changes with no keys assigned to edit/delete. So I assumed there was something going wrong with assigning edit/delete.
I expect if you remove that shortcut, close SketchUp and restart, it’ll be back.
