Cannot save file - model broken won't fix it
Hello
Try to save a model (quite some hours in) and when i save it says the model has a error but Sketcup can fix it, But it can’t, end with;
Results of Validity Check.
*** Problems were found that could not be fixed! ***
The entity at address cd8800 has an invalid id (0) destroyed (0)
Any solution?
Rgds // Z
If it helps;
On Sketchup 17.1.173 version for Mac
Try:
Window > Model Info > Statistics > Purge Unused
It is definitely a bug and has been noted before, e.g. in
I don’t think anyone has yet figured out quite what triggers this bug.
So…basically restart?
Did Dan’s suggestion not help? Another thing you could try is to select everything in the model and copy it into a new blank model (this will be a pretty heavy operation if the model is large). That often causes SketchUp to discard cruft that has accumulated in the model’s database of geometry.
Hello
Nope, Dans suggestion did not help. Ill try to copy it I guess
Thanks guys
That worked - thanks Siba!!!
