Hello, I’m experiencing an issue with SketchUp 2024 that I can’t seem to solve myself.
I have updated the SketchUp of our workplace to version 2024 and did a brand new clean install.
Now I seem to be unable to open any old SketchUp files.
I have tried setting up default apps through “Open With” as well as through the Default Apps section under Windows settings, with no success.
This is on a Windows 11 machine.
Would appreciate any feedback or solutions.
Update 2:
As weird as it is, I am able to open my SKP files, if I navigate to them through the SketchUp 2024 Welcome Screen. They open without problems.
However, double clicking on SKP files brings up the error.
I’ve installed it the same way I’ve been doing it the last 12 years - by making sure I run it as administrator, to avoid issues. Never had a problem with it.
Further reading showed me that some people had luck by uninstalling all current versions, restarting their machine, and installing again. I might try that if no fix comes up. It’s just a shame because I spent the past 1.5 hours reinstalling my plugins and templates/styles. I guess I gotta do it again.
If you are unable to change the default app setting using either of these methods, you may need to delete the registry key that stores the default app settings for that file type. To do this, follow these steps:
I was gonna say … an uninstaller only removes file it (as the installer) itself installed. These files are usually only in the %ProgramFiles% and %ProgramData% paths and not in the User’s %AppData% paths. So any files you manually added later should be “safe” and remain untouched.
