Hello all, im using sketchup 2023 and decided to upgrade it into 2024 version, at first it works well, until i shut down my computer, go to sleep and start again the 2024 version
after this, i can’t open any files. when i clicked it just exit the application
my graphic card is fine, im using i-14700kf with 4070 super.should be more than enough
is it possible because of firewall or something? or the settings?
thank you
I encountered the same problem, but thanks to the sketchup file which is in the user temp
(windows key + r) type in the run “%temp%”
I saw that it was stopping on the load of an extension (ProfileBuilder 4) I renamed the file DM_ProfileBuilder4.rb which is in the extension directory “%appdata%\SketchUp\SketchUp 2024\SketchUp\Plugins” and sketchup has become completely stable, even with the small 100 other extensions
UPDATED! IT SOLVED GUYS!
so i uninstall with third party app (im using iobit uninstaller) then i reinstall my sketchup,
it normal again
thanks to lexxar! simple way and solved thank you thank you thank you!!!
