Cannot negativaly push/pull faces
As shown in the video, I cannot do it. I type -20 and nothing happens
That’s strange, have you restarted the program, it can solve things like this sometimes, if that doesn’t work, could you share the file so any of us can check what’s going on?
Push inwards to arbitrary position and let go of the L-mouse button. Then type -20 and hit [Enter]
-20 should then be in the opposite direction measured from face initial position.
Instead of pushing or pulling with a negative value, can you do the opposite action (pull instead of push or push instead of pull) and then use the same value ?
it worked. thanks guys
