I found this model of a bed on the Warehouse but I cannot change it in any way.
Lay+King_Bed_Walnut_SU2017.skp (11.4 MB)
Does anyone have any ideas what I might be doing wrong
I have tried using the Scale tool and also Fredo Scale but it just snaps back after everything I do
It’s a dynamic component once you get inside the top level. You can resize it with the dynamic component Options panel or explode it to get rid the the dynamic attributes.
If you were using SketchUp Pro instead of Make you could also modify the dynamic component attributets to whatever you want.
Thanks. Exploding it worked. I don’t need to change the kind of things that are options in the Component Options. I don’t normally consider Dynamic Components since I am working in Make
how can I tell if something is a dynamic component
In SketchUp, Dynamic Components have a green DC badge in the Components panel.
thanks
