Hello, Please help solving my problem! I used plugin slicers5 to slide my object. When it finished, it hide all my object. It is still there but I can’t see it or doing anything to it. Please anyone tell me what to do please! I need my object back!
You would be much better off posting this in the tool’s own threads here.
http://sketchucation.com/forums/viewtopic.php?p=374969#p374969
Fortunately, as its author, by luck I have seen this here…
Use the Layers-Panel to switch your layers’ visibility on/off - the original object that you chose to slice is reassigned to layer “SLCR-HIDN”, which is then ‘hidden’, so you can see the results clearly…
Other layers used by the various slices also have names that start “SLCR-…”, so you can also toggle these on/off as needed…
PS: I re-titled your post so it’s more obvious…
