Can someone please help me set the dimensions in SketchUp Make
Hi,
My name is Steve and I recently started to use SketchUp Make.
I am getting frustrated while trying to set up a simple 2x4 wall frame for a small project I have. I am trying to model a 2x4 and cannot get it to snap to the proper dimensions.
In the dimension box I can’t input any numbers or when I drag the rectangle tool to make one at the dimension I want, 8’, the box never ends on a whole number, always too short of too long. It isn’t easy to stop at a whole number either.
The videos and other reference materials don’t seem to have this problem. Do you know what I am doing wrong or does this version not support inputting the dimensions?
Thanks,
Steve
Start a rectangle, take your hand off the mouse, type <96,1,5> press enter. report what happens.
Shep
Edit: entry above should be 96,1.5.
Steve, check your private messages.
Following what Shep says should work (don’t type the <> characters). The most common mistake people make is to mouse-click into the dimensions field, don’t do that, just draw the object and type the characters.
A bit of a visual for you.
Cool keyboard inclusion!! I would have never thought of it and it comes as an option if you are running WIN7. At least in Home/Premium and up, I have the Pro upgrade for 2 years now. As it adds a bit more functionality and visuals cue’s to your famous .gif examples. COOL addition and work …Peace…
I get a face 96" long and 1" wide.
Shep is using a non-American English keyboard setup. Try 96,1.5
Too bad, I was hoping that I had missed being able to produce a 3D shape using {blue, red, green}.
There might be a plugin that draws a box from three measurements, but strangely enough the rectangle tool only draws rectangles :wink:
No, I’m afraid that’s just an American typo.
Sorry folks, I’ll bump up the caffeine.
Shep
I did think it was possible too, but in the meantime you can make a rectangle, type its width, its height Enter, then use the push pull tool, pull the face up by any amount, and type its height Enter.
Yes, I know. My problems are knowing which way the rectangle will be formed and being able to produce a rectangle in the Blue direction without Orbiting a lot.
It shouldn’t take much orbiting if any. You can also choose a standard view that makes orientation of the rectangle automatic.
Thanks for that! Never gave Camera Views a thought. Front works great!
It worked! Thanks for all your help. It takes time to get used to not clicking on the dimension box to enter the length and width.
I have some tutorials to look at now to see if I can get the rest before I ask for help again. I do appreciate the time you all lent me.
Steve
It’ll come soon enough. :wink:
