Can not save sketchup file
Hello! This is my first time using sketchup and I am trying to save the file but it is saying that I need to save it to an earlier version. I see that this is a problem someone has had previously so I tried to delete furniture that I imported from the warehouse but I still can’t save. Please help me because I can’t figure out what the corrupt item is in my file. Thank you kindly, Angelica
Hi, Can you share the file? I´ve never seen something like that.
This has happened to me a couple times. You can’t ‘back save’ it.
Open a new blank SKP model.
Copy all the geometry in your model.
Paste in place into blank model.
Save the new file.
Quit SkethchUp (might need to force quit on Mac).
If you have scenes and section cuts etc. in the original model - open that file, select only the geometry - delete.
Purge the components and materials. Save As something new…
Open the new file.
Copy all the geometry.
Paste in place into the ‘save as’ file.
Thank you kindly, How do I share the file with you?
Angelica
Just drag the file into a comment, or use wetransfer for files bigger than 16mb.
Because the file can not save, I can’t send it to you
Did you do what Mike suggested? Copy everything and paste it into a new file.
Thank you so so much bmike, this worked! Much appreciated.
Great. Mark it as the solution to help someone else that is looking for help with this issue.
