Camera clipping
Hello. I’ve ran into an issue with what I believe is called Camera Clipping? When zooming in on my model (specifically the front approach, other faces are fine), the model begins to fade out. Any fixes? Thanks.
Generally this happens when you have geometry spread out over a large distance. What’s with those edges in the far distance?
Share the .skp file with us so we can see what you’re working with.
Created a rectangle previously to work on. Deleted them just now and still didn’t work. Here’s the file.
Carrier 2.skp (2.4 MB)
You missed a short edge segment. Orbit around so you’re looking downward at the model and then click on Zoom Extents. You’ll see your model gets tiny. Drag a right to left selection window around the empty space and then press Delete. Hit Zoom Extents again.
BTW, please correct your forum profile. SketchUp for Schools is not 2025 Desktop.
Ah, thanks. And I’m assuming Schools is 2024?
No. It’s just SketchUp for Schools. THere’s no year identified with it. Every time you open it you are opening the latest release.
