CAD Importing as 3D
Hello - When I import a .DWG from this one architect, its coming through as 3D but not in a good way. Does he need to change his export settings or is there a way to import / change to 2D (a true flat 2D, not just parallel projection)? I want to trace over it easily and then push/pull as needed. Thanks much!
Maybe the simplest thing is to select the CAD component and scale it vertically to make it flat.
I like to use Eneroth’s Flatten to Plane when working with/importing CAD files.
(post deleted by author)
Tried the Extension first and it worked perfectly! Thank you both so much!
