Hello guys,
For some reasons when I add an equation to simply report a number it bug the whole thing. If you look at the gif bellow, it scale without breaking the component even if it works poorly, but then I had the equation and the component is broken.
The equation is not used anywhere other than being called in the upper component and then used in reports. Its not used to position anything, its just used to report a number, then its called in the upper component to expose it more easily during reports.
The equation;
= IF ( Coin_Corner!B_Structure_Color = “VR_Aluminum_Brushed_70cm_Black” , ROUND ( ( ( ( Corner_SW7440_R_01!LenZ + Corner_SW7440_L_01!LenZ + Corner_SW7440_R_02!LenZ + Corner_SW7440_L_02!LenZ + Corner_SW7440_R_03!LenZ + Corner_SW7440_L_03!LenZ + Corner_SW7440_R_04!LenZ + Corner_SW7440_L_04!LenZ + Corner_SW7440_R_05!LenZ + Corner_SW7440_L_05!LenZ ) / 30.48 ) / 2 ) * 2.10 , 2 ) , ROUND ( ( ( ( ( Corner_SW7440_R_01!LenZ + Corner_SW7440_L_01!LenZ + Corner_SW7440_R_02!LenZ + Corner_SW7440_L_02!LenZ + Corner_SW7440_R_03!LenZ + Corner_SW7440_L_03!LenZ + Corner_SW7440_R_04!LenZ + Corner_SW7440_L_04!LenZ + Corner_SW7440_R_05!LenZ + Corner_SW7440_L_05!LenZ ) / 30.48 ) / 2 ) * 0.552 ) + ( ( ( ( Corner_SW7440_R_01!LenZ + Corner_SW7440_L_01!LenZ + Corner_SW7440_R_02!LenZ + Corner_SW7440_L_02!LenZ + Corner_SW7440_R_03!LenZ + Corner_SW7440_L_03!LenZ + Corner_SW7440_R_04!LenZ + Corner_SW7440_L_04!LenZ + Corner_SW7440_R_05!LenZ + Corner_SW7440_L_05!LenZ ) / 30.48 ) / 2 ) * 1.64 ) ) , 2 )
The bugged part ( POSITION > Z ) of one of the affected pieces
=IF ( Coin_Corner! C_Nbr_Panels >= 2 , IF ( Coin_Corner!D_Spacing_Transom, ( ( Coin_Corner!LenZ - ( Corner_CrossBar_J_Top!LenZ + Corner_CrossBar_J_Bot!LenZ ) + Corner_CrossBar_J_Bot!LenZ ) / Coin_Corner!C_Nbr_Panels ) * 1 , IF ( Coin_Corner!E_Height_Transom_01 < Corner_CrossBar_J_Bot!Z + Corner_CrossBar_J_Bot!LenZ , Corner_CrossBar_J_Bot!Z + Corner_CrossBar_J_Bot!LenZ , IF ( Coin_Corner!E_Height_Transom_01 > Corner_CrossBar_J_02!Z, Corner_CrossBar_J_02!Z - Corner_CrossBar_J_02!LenZ , Coin_Corner!E_Height_Transom_01 ) ) ) , Corner_CrossBar_J_Top!Z )
Thanks for the help.
The file = Download sketchup file (1 week available)
