Bug Splat, fecha o meu arquivo. Uso a versão Pro 2025, mas até alguns dias atrás, usava a versão 2024, e tinha o mesmo problema.
Bug Splat, close my file. I use the Pro 2025 version, but until a few days ago, I used version 2024, and had the same problem.
did you send the bugsplat report ? if so do you know the number ?
can you share the file here so we can rule out some things ?
Upload your file skb and skp to see whats happen
I found your two bugsplats. It looks like you were using SketchUp for a long time before the crash happened, and then did something in particular that led to the crash.
If the crash happens again, see if you can notice what was the action you had just done. Open the model and try that action again, and see if the crash happens every time you do that thing.
