Bug on selection on SU21 on Mac french release
Hi all,
Please find my configuration
Please find my Sketchup release
Please see my extension
When I open the enclosed model and click on the windows Sketchup crash 100% of the case
Sans titre.skp (519,8 Ko)
The file is save on the desktop
Thanks for your help
If I select something else first , its work normaly ???
Which extension needs updating?
Please remove your serial number from your post, it’s yours and not for the whole world to see…
attribute inspector. I update it and its work.
I’m suspecting , this is not the reason of crash because, extension wasn’t activate and its was still bug. But now it’s ok (?) .
Whatever thanks for your help
Do you mean Mac SN ?
I have had some issues with some older files with some very old styles in it
I get an immediate crash if I click on the wall with the window in the model you shared. Bug Splat submitted Crash #59048
The wall and the windows have attribute and ifc classification. May be its help
I didn’t work out what is wrong yet, but if you hide Entity Info, explode the component, make it be a new component, then the crash goes away. Even if you show Entity Info again.
It’s like something is being put into the Entity Info window that leads to a problem.
@denis_bolomier yes, I meant the Mac serial.
In which version did you apply the 2x3 schema?
the 2x3 deliver with Sketchup.
One thing, I start the model with Sketchup in english with my mac on pc
is there a reason for the main component being in inches, whereas the nested are in cm?
though the classification seems to be the culprit, I suspect the parsing to the DC options dialog is more likely to be the cause.
I have seen this with other .skc’s like this one:
NAHB.skc.zip (12,1 KB)
remove the .zip extension, first by unzipping
Im working in Inches for devloppment because in ruby everything is in ruby. but after I switch to centimeter because i’m not american. I will check this skc tonight
