I have a circular cup drawn and need to draw a strap across the middle.I’m sure there’s an easy way to do it. I’ve done it in the past but I can’t remember how. The attached picture shows some cups with the strap there. The skp file shows what I have drawn and now need to add the strap to.
Select and delete the unwanted faces on either side of the strap.
Get Push/Pull and hit Ctrl (Option on Mac). Then push the face down to create the required thickness. Don’t worry about the reversed face at this point.
That’s the process I tried but the attached skp file shows I end up with an open top and what looks to be construction lines on the interior rim within the strap area.
Those vertical lines are a result of Push/Pull with the edge of the hole being exploded into its individual edges. You won’t want those edges or faces anyway so you could just erase them. Then to fill the top of the strap, trace one edge segment along the curve. After getting the face on top of the strap, erase the edge segments at the ends of the strap. Hitting Ctrl before Pushing simplifies the process. Also make sure you correct any reversed faces.
In my screen first instructions, only the top face was reversed. Erasing the edges at the end of the strap automatically fixed it, though. If you still have any reversed faces after the geometry is complete, right click on them and choose Reverse Faces.
To give you an alternative method that may be more appropriate in some situations, you could draw the cup without the central hole. Then draw the shape of the holes.
You have a gift for this. I’m never sure I’m describing the problem properly but you see what I want and offer clear solutions and sometimes multiple solutions. Amazing!
