Hello
In a graph, I create a rectangle on the XY plane,
I project the UVs along the Z axis
I group this rectangle,
I create 3 new copies with a translation and a rotation.
The UVs are correct and follow the transformation.
In Sketchup after importing the live component
Ditto the uvs are correct.
I detach the definition and inspect the bounding boxes of the copied groups by selection,
The bounding boxes are wrong and give the impression that the groups were created after the transformations and not before as in the graph
When I report on the copied groups, they don’t have the same dimensions.
A report as is impossible.
It is imperative to correct this otherwise the live components will not find their public.
We need to be able to quantify our projects in order to be able to sell them! Otherwise it’s just drawing not design.
Thank you for reassuring me about the correction of this huge bug.
Today there is no node to create a subcomponent with its axis system and origin. This is a big shortcoming! Because it prohibits reports on positioning.
graph link : https://creator.trimble.com/graph?assetURI=whp:ecdccf89-7a77-4b24-9c7a-bddfe1a9170f
