OpenGL
Distributeur ATI Technologies Inc.
Moteur de Radeon ™ RX480 Graphics
Version GL: 4.5.13506 Compatibility Profile Context
Format de pixel
DBL RGBA:8-8-8-8 Depth:24 Stencil:8 MSAA:4F:1
Avertissements OpenGL
(blank, nothing)
I just launch the installer with right clic and “run as administrator”.
I launch Sketchup from desktop icon with double left clic.
But i try to launch Sketchup from a 3D model and i have blankscreen for the new window, but the old other still works
So you can have something in the workspace area. Many starting SU templates can look quite blank. Maybe just an axis. Is that the case, can you draw anything in the workspace? Can you upload a screenshot of what you are seeing?
The OpenGL function calls SU requires come from the graphics driver. SU require some of the lesser used OpenGL functions which other programs do not use. Historically AMD driver developers have been known to leave out some of the less used OpenGL functions.
For a nice looking lines, shoot for 4x anti aliasing. You can go higher, but 4x looks nice and is less demanding on the graphics card. Different drivers can provide a different set of OpenGL functionality depending on the developer’s mood.
In SU > Window > Preferences > OpenGL, disable Use fast feedback. This doesn’t kick in until a model gets a lot larger anyway, and you can live without it.
In SU > Window > Preferences > OpenGL, do not enable maximum texture size unless you really need it for something like ray tracing rendering.
Go to your graphic card control panel, the 3D Settings. You should be able to customize settings for individual programs. For SU, both anti-aliasing and anisotropic filtering should be set to application controlled. But you can try tweaking things here too.
