Benefits of working with only components
A modal window is a window that coves its parent window and prevents any interaction with it (and pauses execution of the thread). If you enter “UI.messagebox(“Text”)” in SketchUp’s Ruby console a modal window will show up.
Maybe the window you are describe isn’t truly modal but it sounds similarly distracting.
Here’s a screenshot of it. As I said above, quite clunky.
52
@eneroth3 Julia, I wish I had your facility to write code. All that is needed is a modest notification when you open a component to remind you that it is a component. The word component would do. You don’t need to be told how many instances because Entity info tells you that. You certainly don’t need a window taking up so much real estate with traffic lights etc. Any such notification should disappear automatically as soon as you start on the next command as it will have served its purpose by then.
But I make my cabinet doors/drawers open with “on click”. I think using Components is the only way to do that. I just created a cabinet with opening drawers as a Group (I exploded the components). Believe it or not, when I copy/paste the group it STILL is linked to the original (opening a drawer on the one opens the original), UNTIL I open it once. Then it becomes a unique group but with the same name. Quirky.
Another reason I use components is to export a parts list, though it no longer works since SU “upgraded” the “Generate Report” (no longer puts each part on it’s own line).
In any case, the simple solution is to keep an eye on the number of components in the “edit info” panel (or use “Edit Flag”.
There is a trick that I regularly use when I work on several versions of a project in the same model :
I lock previous versions (select> right click> lock)
So sketchup systematically asks me if I want to make unique, even for nested components.
Use group by:
Thanks Mike! That solved my problem. I didn’t realize I could control the “concatenated” strings that way. I was able to separate parts that we’re different in one dimension (x,y or z).
Very clear explanation - thank you!
Thanks Dave. The main drawback of all components is forgetting to make a unique instance and inadvertently altering the components throughout the model. Very annoying. Otherwise I would definitely make everything components. For the file size if for nothing else.
That has never been an issue for me. Since I know everything is a component and a glance at the Entity Info panel tells me how many instances there are, I can stay on top of it.
I have learned (somewhat the hard way) that using Components is usually the best way to go. I have 2 exceptions where I have not:
  1. When I bring together all the pieces of a large model, I may group them, as the model itself is not intended to be duplicated. (DaveR does lots of furniture models, which could very well be used repetitively in other models, so it makes sense that he always uses components for the whole, as well.)
  2. When I use a plugin to create geometry, I’m very happy to have the plugin create groups rather than components for the internal bits, so it doesn’t clutter my component browser with all the bits that I don’t even recognize. I have downloaded components from the warehouse that have added quite a lot of bits to the component browser, and I really don’t like that…
So I recommend paying heed to the advice of the sages on this forum (in this case, the advice to use mainly components), because they really do know what they’re talking about!
This is a good point. There are some cases where extensions can use components. It would make sense of Advanced Camera Tools allowed you to select a camera from the component browser and place it to create a scene. In most cases though groups are to be preferred. The camera frustrum from ACT is a good example. You want them all to be unique and controlled individually and having them as components would litter the Component browser.
Dave,
Does this add significantly more to your file size? Correct me if I’m wrong but your projects seem to have smaller scope than, say, a detailed house model. I am wondering if this is the correct approach for me to be including in my workflow having maybe a few hundred groups for organizational purposes.
I see the benefit to your approach and it intrigues me but I need to practice some economy with my file size, do you have any input on this thought?
Josh,
I don’t find that my workflow significantly increases file size. It may do so because components have a wee bit more overhead than groups usually do but for me, the benefits of using only components far outweigh any minor file size increase that might cause.
My projects don’t cover the kind of square feet a house would but they are typically highly detailed anyway.
As for whether or not my workflow would be a benefit to you, I guess I’d suggest you try it.
One way you might look at your modeling is to think of it as a sort of finite bank account. Every edge, face, or texture you add costs file size. Where do you need to “spend” your file size? Does the fridge or dishwasher you put in the kitchen need to be anything more than a door? Does the sink really need a strainer in the drain? Does the fireplace need a grate and logs or could you just use an image as a texture? You probably see where that is going. Just don’t add things that really don’t have value in the model for the way it’ll be used.
What do you think?
Yeah, I defiantly keep my polys low, I learned that from my asset creation days for video game models. I just want to be sure my workflow is spelled out before I have it reviewed by my firm to implement at all work stations. I just wasn’t sure how much a component would add versus a group. I will try this out on a smaller project before moving forward. Thank you for your input! very much appreciated.
Hi. I apologise about reviving this old topic, but I have a question and @AK_SAM’s question above Benefits of working with only components - #5 by AK_SAM is the closest thing I could find with a search (without going through a myriad of posts on components).
Which is better for performance, 10 repeated components or 10 repeated groups (each with identical geometry). In other words, is it ‘easier’ for SU to process a reference to a component or to redraw a group of geometry. Just using an arbitrary number 10 here, but I hope you get what I’m after.
Again. apologies if I crossed some boundary by reviving this topic. I am new to this community but I know how some communities can by ‘touchy’ on this.
Thanks for any answers!
To SketchUp, geometry is geometry, so basically there should be no difference. When the file is saved, the component option will take less disk space.
Component nesting (components within components within…) has some adverse effect on performance compared to raw geometry.
Note that unless and until you open one of those groups for editing, the 10 groups will actually be instances of a single internally-managed “pseudo-component” definition. In other words, there will be very little difference between the two cases (10 components vs. 10 groups). Whenever a group is opened, it will truly become unique from any other copies of the same group. After opening one of the 10 group copies, the result will be 9 groups that are all instances of the common group pseudo-component definition, plus one unique group.
I don’t notice a difference between groups or components, except when you edit them (components take slightly longer to edit because you are editing all of them at once, if they are visible… but you can hide them from view)
@Anssi @TDahl @AK_SAM Those three answers combined give me a much better understanding of how these objects are handled internally. Thank you so much for them. Given what I have read in this thread before now, I feel more confident in my workflow now (which is actually not very different from how I worked before but in a totally different context). I think I’ll stick with what @TheOnlyAaron and his colleagues keep hammering down – a combo of groups and components. I am already in a habit to name groups – again, used to that from my previous occupation – so the outliner is my friend lol.
Thanks so much!
