Hi, does anyway know how to bend a flat object. I would like the brick material to radius to the curve of the window head in the attached…Uploading: FYU 4 part N elev.jpg… I’ve tried various options in the texture tool and bending plug-ins but can’t get it to work.
You can’t actually bend a texture in SketchUp. The common method of doing what you are after is to divide the face into small sectors and adjust the texture on each one. Fredo6’s ThruPaint can help in that vein. See: https://sketchucation.com/forums/viewtopic.php?f=323&t=44552
Thanks DaveR. Seems a bit long winded so I will save that solution for a more detailed model!
