Baseboards at doorways, how to remove
Baseboards 2.skp (202.5 KB)
Baseboard over doorway
In the Crown Moulding lesson of the Commercial Interiors course it shows how to create baseboards around a room using Follow Me. I’ve done that. However, the course video told me to simply erase the baseboard at the doorways.
I cannot do that because my baseboards have a curved top. I want online to find how to do it. She recommend using the Trim tool.
The video must have used a SketchUp version from before 2023. I could not find out how to access the Trim tool.
So, my question is, how do I access the Trim tool in SketchUp 2023?
Peter Enns
Trim is in the Solid Tools Toolbar.
Screenshot 2024-03-20 133351
It is also in the Tools menu in the Solid Tools item.
If you want to try a second method, click in sequence on the scenes tabs of this SU file for ideas.
Baseboards 2 - JL - 2024-03-20.skp (349.8 KB)
Maybe you will want to widen the space between the baseboard to clear more space if you are to add a moulding around the opening. If this is the case, simply push the end faces of the baseboard.
