I export a page from LayOut to DWG so I can check what is actually being exported before sending the file to my architect.
When I import that DWG back into SketchUp, I have two problems:
The floor plan itself appears, but the blocks I placed in LayOut (for example a bed, a sofa, and other furniture symbols from the Scrapbook) are detached / separated from the plan. They are no longer in the correct position on the plan.
My title block does not appear at all in the imported file.
I also tried opening the same DWG in AutoCAD, and I get the message “Drawing file is not valid.” The RECOVER command also fails with “Unable to recover drawing file,” even when I re-export using an older DWG version (2013 / 2010).
Is this expected behaviour because LayOut entities are in paper space and SketchUp only reads model space?
Is there a way to export a DWG from LayOut so that the plan, the LayOut blocks, and the title block all stay together in the correct position and at the correct scale?
Not sure as I don’t use this feature but I believe there were improvements in 27 for this functionality. You could install and try - it doesn’t affect your current install.
If AutoCAD won’t even open the file, what are you sending your architect for now, a PDF? And when this happened on earlier projects, did they have to fix or redraw parts on their side? I work with an architect myself and I’m trying to understand where these handoffs cost the most time.
What version of AutoCad are you exporting to, and what version are you using to try to open them? I understand that the Mac version of AutoCad has not been updated in many years so the format you are exporting to might be too new.
For my part, I do everything in SketchUp and LayOut. When he asks me for the interior layout I’ve done, I export my LayOut plans to DWG so he can simply overlay them onto his own plan, instead of just sending him a PDF. He often needs measurements that are missing from a PDF.
I’m using SketchUp and LayOut 2026. I exported in DWG 2013 and it still doesn’t work. However, when I import the file back into SketchUp, I can see my things.
Do you need the view in LO with titleblock and all? Or would a proper export out of SKP work for his overlay? I use Curi2Cad for this. Works great. Setup your scene, export, etc. In the paid version you can setup sets and map tags to layers.
Can you post a LayOut file and a DWG exported from that that shows this problem to you? It would also help to see a screenshot of the settings you use when exporting.
