Auto Scale in Layout changing when trying to dimension
I am trying to dimension a drawing imported from Sketchup in Layout. Some lines(walls) will dimension to the dimensions I put in sketch up drawing and other lines the “auto scale” changes to 1:1 instead of “not scaled”
Upload the LayOut file so we can see what you’ve got going on. If it’s too large to upload here, upload it to Drop Box and share the link.
Im pretty sure you have to make sure that auto scale is selected then save as a template so that layout knows that’s the default.
That’s not required.
Most likely you are snapping the dimensions incorrectly. @DaveR Has the best advice, share the file that is causing the problem and we (the Forum Community) can help you out!
