Good morning,
Hoping someone can help me figure out how to do this in terms I can understand. I’m fairly new and learning everyday so bare with me. I’m trying apply wallpaper and I can’t seem to apply as one smooth texture. It’s applying as tiny squares on a repeat and if I make the pattern bigger so it doesn’t repeat as much the scale is way off. I need specific wallpaper too, I can’t just put anything on there.
Thanks
You need a large enough image that shows the whole repeating pattern and then use an image editor to trim it so that only the repeating pattern is left so the result is seamless. It might also require a correction to the exposure so that the result is uniform.
