spawn
June 24, 2017, 8:55am
1
Hi everybody.
I found on internet a picture of 3D model of a house that looks like a cartoon.
So far this is the only thing I was able to do it.
Am I on the right way?.
Any recommendation about how to do it?
This is the file so far:
cartoon_roof.skp (422.7 KB)
Thanks in advance.
anme
June 24, 2017, 10:10am
2
Bevel the edges with the plugin “Round Corners ”.
spawn
June 24, 2017, 10:16am
3
I installed this one, RoundCorner | SketchUcation
Thank you so much @anme , it worked so cool.
Edit: Can I set the offset value dragging the mouse? because I don’t get it. Entering the value works.
anme
June 24, 2017, 10:26am
4
You’re welcome.
The adjustments works only on mouse click or entering the value in the parameter bar.
spawn
June 24, 2017, 10:32am
5
@anme
Sorry for annoying again, I’m like a pain in the neck, I know.
Offset value can only be defined this way then?
Anyway, this was the result:
anme
June 24, 2017, 10:37am
6
I forgot the offset can be changed on VCB without the mouse click on parameter bar. Just press the value and hit Enter.
spawn
June 24, 2017, 10:41am
7
@anme , I’d like to know if it’s possible to define it with the mouse button, I mean dragging, because I don’t find the way.to do it. Wherever I click trying to drag, the selection disappear. Thank you again.
anme
June 24, 2017, 10:48am
8
There is no option for dragging. Doesn’t work that way.
Click on plugin icon. One of three options;
Type the offset value without click anything and hit Enter ;
Click on edges. On at a time. No drag.
spawn
June 24, 2017, 10:53am
9
there is no way without typing the value?
I mean … just using some handle?
If you confirm I can use drag a handle holding left mouse button then I will look for some tutorial on youtube.
Because so far the only way I find is typing the value.
anme
June 24, 2017, 11:11am
10
No. Just typing.
At same link you have posted, there is a Quick Start tab.
DaveR
June 24, 2017, 11:20am
11
Give it up. The only way to set the Offset is via the keyboard. Just type the offset value.
You can pre-select the edges before starting Round Corner.
spawn
June 24, 2017, 2:03pm
12
thank you all, mates, sorry for bothering.
