Hi, I would like that my door, which is the square, would open rotating around the red axis, but when I animate it, it falls back on the Y axis.
Can anyone help me please?
Thank you
Thank you
I still have an issue whith this. It seems like the component does not accept the new referential axis.
Can you Help
Thank you !
If you upload the (component) file, someone might give it a try.
Layout 3D broyeur.skp (574.0 KB)
Thanks for the tip.
Here is the file, I am triying to open it in the X axis which is in the same angle as the panel.
Thank you
In order for the rotation to work correctly one needs to add the right attribute first and see how much the current rotation is: (-60)
It doesn’t work. When I set an attribute for a Rotation, the component adopt immediatly the angle input.
You are editing the component file itself, instead of importing in a working file , I guess
It once worked, but I can’t make it happend again…
If anyone is willing, I would do a TEAMS with shared screen…let me know.
Leave me your e-mail below, with a time, and I will send an invite.
Thank you for the support !
first open rotation attributes
add an attribute to hold the required values
note the other values automatic zero out
change onclick to suit
Thank you for all the support, but it still doesn’t work even with all of the attempt with your advices.
Thing is, I was able once to set it just by placing the axis in the right direction on the component.
I will keep trying.
It would be nice to have a shared screen online help or forum. Does that exist?
Thank you
