I am trying to make a front door a dynamic component so it opens onclick, but cannot figure out the formula since it is on an angle and not directly lined up with an axis. The formula is what I’m struggling with if anyone has some direction?
place the axis at the hinge line pointing in the swing direction, open all of the rotation attributes, note their values (paper) set these values, they will change after entering first, but continue from the noted until all fixed, Then include the particular value in the onclick parameters if required. removing its fixed value to operate with the animation
another method, if required or preferred is double wrap (extra nest) the door so one axis system is isolated from the other
if you upload the model, can prescribe a solution
