rsims_1
November 17, 2021, 12:03am
1
after creating a floor plan in 2d free web version can you create a title block?
It would probably be easiest to export 2D format, then add a title block in another program like a PDF editor. But, if you want to explore doing this all within SketchUp Free, have a read of this thread:
Sure. I slammed this together pretty quick but it gives you an idea. The title block I made by starting with an 8.5x11 rectangle (the size of the paper I intended) then scaled it up until it fit around my drawing. I put in some 3D text, not efficient, would be easier to add after making the PDF, but doable.
An isometric view is a parallel projection camera rotated 45˚ horizontal and 35.264˚up vertical relative to the object. This makes 90˚ corners appear 120˚. In this case I cannot move th…
