Adding objects to layer to create dotted lines
I have added both objects to a layer but when i select dotted lines only the box reflects the changes ?
Impossible to be sure from a screenshot, but probably the lines in the group? on the right are on some other tag/layer than the “box” or the group itself. Raw geometry (edges and faces) should always be on Untagged/Layer 0.
Thanks for your help, just noticed it does says components (3 in model) so guess i need to separate them ?
Should i explode them or select edit component ?
Open each for edit, select all, and set the tag to “untagged”.
Perfect, thank you
