Has the ‘Add Location’ functioning changed recently? I just tried it and the region selected also includes the scroll bars at the side which should not be occurring (see attached).
Also has the maximum size of map area also now been limited? There now seems to be a maximum region that can be grabbed whereas I’m sure there wasn’t before. I couldn’t grab any larger area than the attached.
Same issue, up till yesterday I was able to import map images without scrollbars showing up in the model, but as of yesterday morning scrollbars show up. My default browser is Chrome, but I tried this also with IE11 and IE10 as default browsers with the same result. Also tried it on another computer (Windows 7 Enterprise 64 bit) with SketchUp Pro 64 bit (vs SketchUp Make like I was using) and IE8 and got the same scroll bars in the final image.
On the “select your location” window, there are scroll bars no matter how far you stretch the window. I tried stretching it across two monitors and still had a horizontal scrollbar.
I just tried it and I’m not seeing it. We’ll keep trying to repro. Can someone post an image?
We’ve ALWAYS limited the size/height from which you can grab. That’s nothing new.
The scrollbars in the first image cannot be removed by making the window bigger. The scrollbars in the second image (model) didn’t start showing up till the scrollbars in the selection window showed up (sometime yesterday). I can also post the source for the selection image window.
You are on Windows 10, which is not supported (yet,) and your profile neglects to state what version of SketchUp (as well as what make & model Graphics card.)
Standard answer is update MS Internet Explorer to latest updates.
If having trouble finding buttons on the toolbar, try to resize the window wider until the buttons all show.
For debugging info:
Go to the 3D Warehouse (in SketchUp: File > 3D Warehouse > Get Models…) and SHIFT+click the red Search button. Copy & Paste the debugging information into a text file and attach to a post here.
