A suggest about table in layout
@tt_su @DaveR
When I insert a table in the document by ruby, I find I can’t edit the table by using excel.
I’m far away to call myself as expert of Layout Ruby API or even Layout, so I could be wrong, but as far as I see:
If you insert a table into document using Ruby API it will be similar effect than inserting by using the Table tool in Layout. That means you can not use the “Open with Table Editor” (excel) to edit it. To be able to edit it with excel, you have to drag and drop the excel file or use File>Insert... method.
I guess the implementation to add Table entity linked to excel file is not added to Layout Ruby API yet… (?)
True. And the C API also lacks this:
