A quick way to rotate objects around?
I’m wondering if there is a simple command that would turn the object around quickly…without having to rotate it in the classic way…something like the turn around blue/green/red axes but turn around in its own pivot.
If there was a command for that I could set a keyboard shortcut and it would be amazing to just press it and see the component or group turning around in its pivot. A good tip for the next sketchup versions.
You can try Curic Rotate
Check this post:
