The software for 3d Connexion is found HERE
Thanks for your answer …I already have the software for 3D connexion…What I’m waiting for it’ s the one for SKP2022 because as everybody wrote here, this is not working for 2023. I’ve made exactly what SLBaumgartner wrote on my last Mac and everything was working but now I have a new computer with no skp 2022 plug inside… I don’t know if I’m clear (sorry I’m French )
I just checked their site, it is the same for ios 11,12,13. Also all the later versions of SketchUp.
@RLGL is correct. The driver was updated since my post. The one on the 3DConnexion site covers all versions of SketchUp through 2023 and both Intel and Apple chips. As always, you must install it after installing SketchUp for it to detect what version(s) you have.
Hi,
It works for you ? Me after copy file 3DxSketchUp.rb and folder 3DxSketchUp wtih 3 files 3DxSketchUp.so, 3DxSketchUp.susig and 3DxSketchUpExt.rb from C:\ProgramData\SketchUp\SketchUp 2020\SketchUp\Plugins
, when i open sketchup it tel me
Erreur de chargement du fichier C:/Users/NeoYoshi/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/3DxSketchUp/3DxSketchUpExt.rb
Error: #<NoMethodError: undefined method `AttachSkpExtension' for TDx:Module>
C:/Users/NeoYoshi/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/3DxSketchUp/3DxSketchUpExt.rb:24:in `<module:TDx>'
C:/Users/NeoYoshi/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/3DxSketchUp/3DxSketchUpExt.rb:10:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2023/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2023/Tools/extensions.rb:197:in `load'
C:/Users/NeoYoshi/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/3DxSketchUp.rb:22:in `register_extension'
C:/Users/NeoYoshi/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/3DxSketchUp.rb:22:in `<module:TDx>'
C:/Users/NeoYoshi/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/3DxSketchUp.rb:11:in `<top (required)>'
Do you find a solution ?
There is no longer a need to go through all that! The latest drivers will install and work with all SketchUp versions up to and including 2023. You should remove all the manually copied stuff, download the latest driver, and run its installer.
Thanks, worked perfectly!
