Hi there,
I keep getting the message “3D warehouse requires internet connection. Please connect and try again”. However, I have internet connection that is working. This problem has just appeared. I have tried to solve this for hours today to no avail.
I have also tried signing out of my account in sketch up but I also get the message “unable to connect please check internet connection”.
Can anyone offer some solutions please? Thank you!
Can you access 3dwarehouse.sketchup.com in a browser?
You might wanna repair the installation.
Best to download the latest version, first.
Then rightclick on the downloaded installer file and choose ‘run as administrator’ when prompted, choose ‘repair’
Thank you very much for taking the time to respond.
I have tried and completed all those options however the problem still exists.
…baffling!
And can you access bing.com in a browser?
Anti Virus software?
Hi,
Thankyou.
I tried again and yes I can access bing.com but still not 3D warehouse nor extensions. Still can’t even log out of sketchup from sketchup.
Sunday day here in Australia, will try a few more things today…anti virus and uninstalling last windows updates.
…???scratching head…
Ok, new idea…
If it is just difficulties in signing in or out, try setting your default browser to be Chrome or Firefox. There are some issues with signing in if you are using IE or Edge.
Hi Colin, thankyou for the idea. Chrome is my default browser and the problem isn’t just signing in and out. It’s also the 3D warehouse and extensions, therfore internet connection with sketchup.
But you do have access to this forum (forums.sketchup.com)
How did you get here? Other machine?
Hi Mike, yep access to the forum, access to normal internet etc from the same machine. Its just sketchup - 3D warehouse, extensions and logging in and out of the program.
…crazy!
It takes a while for me to run out of ideas!
Both warehouses do get upset if port 443 is blocked. Can you test to see if it is blocked?
In the command prompt window you can try this:
telnet extensions.sketchup.com 443
If it gets locked up, or shows any error, the port is blocked. If the screen clears, then the port is ok. Ctrl-c will get you out of telnet.
If telnet isn’t enabled on your system you can get to its checkbox to enable it by opening “Turn Windows features on or off”.
Have you tried by disabling your firewall temporarily? Also do you have more than one security program running?
Thanks everyone for you help. I got it!!!
Ended up being a simple solution…of course! My router had gone into a limited mode and while I had some access it was not functioning properly. Just turned it off and back on and all is working now.
I really appreciate everyone’s input and ideas!
Enjoy the rest of your week.
I am having this issue as well and when I run telnet in Command Prompt i get an error that says “could not open connection to the host, on port 23: Connect Failed” any ideas on what I should do hear
however when i type the telnet command and add the 443 to the end of it the screen clears as you suggested should happen. I still have no access to the 3D warehouse through the sketchup app but can access it from anywhere else on the same computer
We had an issue earlier, where even we saw a message about being offline when trying to access 3D Warehouse. The problem seemed to go away just under an hour ago.
Not mine & I have tried all that has been mentioned above !!!
Still using SketchUp 2018?
yes. SketchUp has not improved enough over the years to move to the annual subscription
