I bought the 2DXY_SlickMoves extension from the extension warehouse. After upgrading to Sketchup 2022 I can no longer use it, it says:
“Failed to obtain active licence for 2DXY_SlickMoves. License Missing.”
I found similar threads where a Sketchup Team member “Colin” kept fixing this issue for other users, it was a closed thread though and I wasn’t able to post there.
Not sure if you can help but I’m having an issue with the same extension after upgrading to 2024. I get this message, “The extension has been successfully installed but was not loaded. To load the extension go to the Extensions tab of the Preferences window and check the box next to the extension.”
I’m not seeing an Extensions tab in the Preferences window.
Thanks,
Nathan
it is not uncommon for a plugin to not launch straight as you install it, I had the case earlier today, a trainee installed solid inspector on his mac but the toolbar didn’t show, a quick restart of SU fixed it.
restarting SU also relaunches all the extensions installed and activated
