I didn’t see this in the release notes, but I see it in my Mac’s file system… Did the backup file extension change to .skb in 2027 to standardize it with Windows? If so, I assume we can ditch the old ~.skp files after editing with 2027?
Yes. The extension changed. Hopefully that will stop Mac users from editing the backup files instead of the .skp.
I don’t see why you couldn’t delete the files with ~ in the name. I’d make sure you haven’t inadvertantly used one of those in a LayOut file though.
On a somewhat parallel thread I posted something containing the instructions on how to mimic what I do on a PC with AutoHotKeys, using MAC background scripts to spot whenever you save a SKP and a SKB is made in the model’s folder, with the same name as the model - which leads to confusion… It takes the SKB and moves it into a SKBs subfolder on your Desktop, with an incrementing numerical suffix to the file name. That way the backup file is never overwritten - like an archiving option. Of course it is customizable for which folders/subfolders to check for arriving SKB files and whether multiple copies of the backup is made [you simply stop it adding the numerical suffix and thereby there is only ever the one SKB]. To be compatible with the old ~.SKP versus .SKB naming of backups it moves both backup types in case you are using v2027 and an earlier one in tandem…
https://forums.sketchup.com/t/skb-files-icon-on-mac-2027/350813/7
