SKB file's icon on mac (2027)
In the newly released SketchUp 2027, which features a UI unified with the Windows version, the icons for backup files appear as a question mark (“?”).
Is this expected behavior? Is there no specific file icon that distinguishes these as backup files?
When I double-click an SKB file, I am prompted to choose an application to open it with; I selected SketchUp 2027 and set it to “always open with this application.” However, instead of displaying the file’s contents, it opens a screen for selecting a template. Is this the expected behavior?
the white icon distinguishes them as backup files.
because skb files won’t open by default in sketchup. before, people would open on accident (or not) the ~ files and work on them. I’ve seen files with 5 or 6~ meaning this was a repeated behaviour.
now, it’s like on PC, no icon because no default opening application. you have to rename as skp to open your backup in sketchup.
I don’t have the ? but I’m still on mac os 15. might be OS specific ?
expected, idk, but the normal procedure is to rename skb into skp. greatly limits the risk of working on the backup and not the original too.
I for one am welcoming this change. I can clearly see what a backup file is and do not accidentally start working with one of those little wiggely-line ending skp files. Drove my team nuts, because everyone is on windows except me and my “special” backup files. Now we are in the same boat!
I know it’s slightly off topic but on my PC I have the same issue that the files are confused and I don’t suppress the filetype suffix but the larger pictorial graphics are confusable as I don’t list bt details > Filetype all of the time. So what I have is a tiny AutoHotKey script running all the time and any .SKB files it finds anywhere on my PC it moves into a SKBs folder on my Desktop. That way if I ever need to use the .SKB I can just rename it .SKP and move it to the appropriate folder elsewhere. It’s reduced mistakes no end - especially when dragging and dropping multiple files into emails… I’m sure there’s something equivalent on the MAC ?
nothing native, but like you, that’s script territory yeah.
that’s actually a good idea, it would make the cleanup easier, we don’t need a carbon copy of models made 10y ago.
The attached txt file contains a step-by-step guide to setting up your MAC to run background processes to move all of your projects’ backup SKPs into a single Desktop folder [SKBs] and increment their name etc as an Archive. Please use carefully and if in doubt ask someone who knows how to help…
MAC_SketchUp_Backup_Helper.txt (5.5 KB)
Incidentally - please note that it moves all .SKB and ~.SKP backup files, depending on the SketchUp version you are using.
Thank you for your helpful response.
I began using SketchUp on a Mac starting with Version 5, so for over 20 years, I have been accustomed to backup files marked with a “~” symbol—files that would launch SketchUp when double-clicked. The recent standardization with the Windows version has been a bit confusing for me, but moving forward, I will simply change the file extension to “.skp” whenever I need to open one of these backups.
That said, I believe it might be beneficial to assign a specific file icon that clearly indicates the file is a backup—even if it cannot be opened directly. This would allow users to identify it as a SketchUp backup file at a glance, without needing to check the file extension (e.g., “.SKB”).
